Castillo__Miguel
4 years agoSensor Aggregation Reference Design.
I am trying to modify the example in https://github.com/intel-iot-devkit/terasic-de10-nano-kit/tree/master/azure-de10nano-document/sensor-aggregation-reference-design-for-azure for my solution but the documentation is a bit confusing and when I try generate the system I got about 96 errors.
- EBERLAZARE_I_Intel
I assume you are using Terasic DE10 Nano for this design?
Can you describe what steps and build did you do that picked up the error that you faced? And if you could screenshot/upload the logs of error here?
Any update from your side?
