8 years agosend image from pc to fpga and receive back to pc
Anyone can give suggestion of send image to fpga for image processing and get back output to pc using quartus ii ? Thank for anyone that answer my question.3 Replies
Refer following link this might help & check “6. Activity flow”, https://ac.els-cdn.com/s014193310700110x/1-s2.0-s014193310700110x-main.pdf?_tid=3965577c-d347-475d-8c59-19d11a6b4ad9&acdnat=1525748335_5043e903eef8f6325d34b07339e1f8d7 Let me know if this has helped you. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel) - Altera_Forum
Thank you for answering my question.
Sorry that I'm still don't had the idea to using method that you given. I had done the gaussian filtering using vhdl code. Then change image to text file and tested by using testbench for modelsim. But now I don't know how to implement it in the de2 board. Can I had some example code or step to do this? I'm still new to doing this project. - Altera_Forum
--- Quote Start --- I'm still new to doing this project. --- Quote End --- Have you gone thoroughly through the document provided in the previous post? Gather & study all reference material related to your project & Start with the Intel FPGA training curriculum, https://www.altera.com/support/training/curricula.html Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
