17 years agoSDRAM on DE2
Hi friends: I come up with a problem on DE2 board.In the SOPC builder,I set the clock of both SDRAM and CPU 50Mhz,when I download the software in Nios,it said "Verify failed between address 0...
15 years agoI found the solution. I had to use 2 clock signals from pll. One for sdram and one for fpga. Then it works.
