17 years agoSDRAM on DE2
Hi friends: I come up with a problem on DE2 board.In the SOPC builder,I set the clock of both SDRAM and CPU 50Mhz,when I download the software in Nios,it said "Verify failed between address 0...
16 years agoThanks - I ended up adding a second clock to the PLL, going straight through,
as suggested by the tutorial. That worked. Interesting though that a few years ago you did not need to send the CPU clock through the PLL. Now if I can get the Terasic ISP1362 (USB) IP to work with Quartus 9.0/9.1.
