17 years agoSDRAM on DE2
Hi friends: I come up with a problem on DE2 board.In the SOPC builder,I set the clock of both SDRAM and CPU 50Mhz,when I download the software in Nios,it said "Verify failed between address 0...
17 years ago --- Quote Start --- --- Quote End --- I think your pin connection or timing are setting a wrong value. Please checking the SDRAM timing in SOPC builder and check pin connection on your TOP file. Maybe you can compare with the example of DE2_70_NET project.
