17 years agoSDRAM on DE2
Hi friends: I come up with a problem on DE2 board.In the SOPC builder,I set the clock of both SDRAM and CPU 50Mhz,when I download the software in Nios,it said "Verify failed between address 0...
17 years agoHi.
I'm not sure but, check the SDRAM controller code, also you need to delay the SDRAM clock -3ns.
