13 years agoSD Card UP Core
I cannot get the core to work.
I have installed the newest UP cores in the Altera 12.1 directory as described. I have a working system without the SD Core, SOPC Builder works ok, system download fine and works as expected. When I add the SD core (I named it "sdcard"), the system generation is successful. I add it to the top level design (bsf method). But then I get always an error when compiling the design: Error (12006): Node instance "sdcard" instantiates undefined entity "Altera_UP_SD_Card_Avalon_Interface" What am I doing wrong? Regards, Friedrich1 Reply
This thread:
Using SD-Card reader on DE1 board (with Nios) showed a solution. It works for me, I had to copy the necessary *.vdl files manually in my project directory. THIS IS A NASTY BUG THAT NEEDS TO BE FIXED! Kind regards, Friedrich
