13 years ago
SD Card read fails on NIOS2 DE2 Board
Hi guys,
I am a university student trying to get the demonstration project working. The project that I am trying to get it to work is, DE2_SD_Card_Audio. I am able to synthesize and transfer the SOF file to the FPGA. However, when I run the NIOS 2 project on the FPGA, I get the following error,
[AUDIO] set audio reg[15] = 0000h
[AUDIO] set audio reg[09] = 0000h
[AUDIO] set audio reg[00] = 0017h
[AUDIO] set audio reg[01] = 0017h
[AUDIO] set audio reg[02] = 005Bh
[AUDIO] set audio reg[03] = 005Bh
[AUDIO] set audio reg[04] = 003Dh
[AUDIO] set audio reg[05] = 0000h
[AUDIO] set audio reg[06] = 0000h
[AUDIO] set audio reg[07] = 0042h
[AUDIO] set audio reg[08] = 0002h
[AUDIO] set audio reg[09] = 0001h
[AUDIO] AUDIO_Init success
[AUDIO] set audio reg[02] = 0078h
[AUDIO] set audio reg[03] = 0078h
[AUDIO] set Line-Out vol(120,120) success
Please insert SD card.
find sd card
[fat]read section 0 error.
[fat]fat_mount fail
sd card mount fail.
How do I fix this ?
    There could be a speed problem. I had two SD cards, one is rated class 4, the other one is unrated. The unrated one could not work. They both are FAT16. I have tested both of them on DE2 + DE2-70 platforms. Some problem.
    I have a SanDisk Ultra 2GB but as I said it works with the Audio project. Is there a way to flash a LED on the DE1 board when the SD is detected?
    Guys, I tried it with a brand new 2GB SD Card, Formatted as FAT16 system, unfortunately I still get the same error,
    Find SD card
    [FAT]Read section 0 error.
    [FAT]Fat_Mount fail
    SD card mount fail.
    I have a similar problem as wangrin. My board is also DE2 and SD card is 1GB which is formatted to FAT 16. Has anyone already solved this? Thanks in advance.
    Same problem with 1G sd card no matter in FAT16 or FAT32, anyone could help??or where can i found reference about this problem?
    I have same problem. I am unable to read the SDHC micro-SD card which has been formatted to create a 512MB FAT16 partition.
    I get the SD card mount fail error like a slap on my face.
    All these reference designs I have tried on this FPGA DE2-115 board have issues with them.
