11 years agoSD card HAL driver cannot write large files correctly
Hi I'm using UP sd card interface and it is worked perfect till I write small files - I can open it on my PC and read. But if file size is more than about 4K I get Windows error when I try to open...
11 years agoHi, I recently work on FPGA of DE2-115.
I tried to modify the demonstration, DE2_115_SD_CARD, provided by Terasic to write the data into SD card. However, none of my method succeeded..... Can you share with me how to use the "University Program SD Card IP Core" to write data into SD card? Or just create a text file in SD card? Any of your help is highly appreciated. Thank you very much!!
