9 years agoRS232 IP Core on Ubuntu -- DE2-115
I am using the RS232 IP core to send info from a DE2 board to a computer running Ubuntu. When run on Windows, the controller works fine, but when run on Ubuntu the something interesting happens and I cannot find any help with this issue. Here is what I have. A sample project (not the actual project I'm using, but something I made to debug the issue, the same thing happens in each):
module serial(
input CLOCK_50,
output UART_TXD,
input KEY
reg data;
reg valid;
wire reset;
assign reset = ~KEY;
uart u0 (
.to_uart_data (data), // avalon_data_transmit_sink.data
.to_uart_valid (valid), // .valid
.clk (CLOCK_50), // clk.clk
.UART_TXD (UART_TXD), // .TXD
.reset (reset) // reset.reset
reg preKEY1;
always @(posedge CLOCK_50) begin
if(reset) begin
data <= 8'd5;
valid <= 1'b0;
preKEY1 <= KEY;
end
else if(KEY != preKEY1)begin
data <= data + 8'd1;
preKEY1 <= KEY;
valid <= 1'b1;
end
else begin
data <= data;
valid <= 1'b0;
preKEY1 <= KEY;
end
end
endmodule Essentially the code is meant to let me output characters by pressing the buttons on the board. When I load this onto the board and press the reset button, I enter into the Ubuntu terminal: sudo cat /dev/ttyUSB0 to retrieve the output from the serial port (I am connecting through a USB converter, which think may be part of the problem, but I believe I have set that up properly) When I press the button the board, characters appear in the terminal as expected, but the characters are all � (the ascii replacement character). No matter what I've tried I cannot get the computer to output anything else. Any suggestions are welcome.No RepliesBe the first to reply
