18 years agoReference design for Nios II Embedded Evaluation Kit, Cyclone III
Hi all... Part of my final year project I should built a system in FPGA to control Actuators through the connection RS_232 from the Nios II Embedded Evaluation Kit, Cyclone III ... I would...
18 years agoHi,
Not quite sure if you're after schematics, software or connector/cable info. Check out http://www.altera.com/literature/ds/ds_nios_uart.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=rs-232 for info on the NIOS UART. I can't remember whether the NIOS Eval board has a 9 way D for RS-232 or whether you need to access the interface through the HSMC connector. Check the documentation that came with the kit. It should be in there somewhere. Good luck
