13 years agoRead audio from flash- wm8731 codec
Hello, I am trying to make a system that stores some audio samples (~11secs) to the flash of the DE1 Board and then playback them. Right now, i only would like to play correctly the audio sampl...
13 years agoOk, since i was running out of time, I changed approach and used an only-hardware based solution.
It is based on starterkit provided by Altera, so I don't need to provide in-out fifos or to detect conditions or configure the CODEC. Furthermore, I am still using the altera university program flash controller to access the flash. Now, I am able to store 2^21 bits of data in the first half of the flash memory and 2^21 bits of (different) data in the upper half of the flash. And I am able to correctly play them to the speakers. Now introducing the nios processor should take less than a quarter of hour, but I am a little bit sad that I had to use someone else audio decoder. Well, I suppose that in complex systems is natural - and way much faster, and obvious - use third part software/hardware. But for a simple project, I would be pleased to do it on my own. Anyway, since it is a (minor) project for an univeristy course, I won't publish it here until the exam will take place. But if someone is interested, feel free to contact me. Best regards, P.
