FPGA Monitor Program 18.1 Tutorial: Could not query JTAG Instance IDs. Please ensure the FPGA has be
> Please try compiling and downloading the program.
Please advise how to achieve this.
> Yes, we do have access to the board and the Monitor Program, but we cannot reproduce this issue.
This is good to know. It is much appreciated if you would share your project file, the assembly source files and specify which version of Quartus and "Intel FPGA Monitor Program" you were using, the steps you performed, the screenshots and the messages in the "Info & Errors" panel after the run.
My project, "arm_de10_nano_asm.amp" contains two assembly programs: "simple_program.s" and "address_map_arm.s".
When I run "Actions/Compile&Load" I got "Loading errors".
Please find attached a screenshot and the "Info&Errors" messages.
It looks like we went the full cycle, back to where we started with the subject line: "Could not query JTAG Instance IDs". Should I change the subject line again or we all know too well what the problems are?
phiho
Hello Blair,
It is hoped that the attached screen shot and "Info&Errors Messages" came through. Please advise if you need them resent or do you need any further information to resolve this issue which was first reported 01-23-2021 02:00 AM.
Looking forward for your advice.
phiho
