Failed to initialize user clock?
- 5 years ago
Hi @davidwigley,
Thank you for posting in Intel community forum and hope all is well.
I have tried the instruction in the similar nodes mention and are able to program successfully. (i.e. complete steps 3.6)
Hence suspecting there might be some missing steps, would suggest to to check on the following:
1) Selecting the correct development stack source which is 1.2.1.
2) Recompile the program by running make clean followed by make command.
3) Are you able to compile the opencl code into the FPGA executable successfully?
Please do try and let us know if that helps.Best Wishes
BB
Now the issue occurs after programming the device, without error.
Upon execution, it terminates by saying:
Binary length is 15988 for 1 devices
Context callback: Malformed program binary: missing .acl.board section
Context callback: kernel argument info is not available
Context callback: Invalid binary
ERROR: CL_INVALID_BINARY
Failed to create program with binary
Has anyone seen this before?
