BoonBengT_Altera
Moderator
2 years agoHi @MPH23,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
MPH23
2 years agoThank you for your support
I have tried to create the HLS environment a lot in Quartus 19.1 Standard Edition but couldn't then I installed Quartus 23.1 Standard Edition where I am able to create the HLS environment through the command prompt and had executed the QRD example which is already present in the HLS installation.
Now I want to know that at present I have execute the examples that are already present but if I want to create my own HLS file in which software I will build or how I will build the .cpp and .h and verify or debug my code as I have seen the HLS is executing directly from the command prompt, it is not opening as an interface where I can write my HLS code as like I can write the VHDL or Verilog code in the Quartus interface but I have not found any interface for HLS.
Attachment: Execution of the QRD Example
Please help me in this regard.
Thanking you
