17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years ago --- Quote Start --- hi everyone, I'm trying to transmit audio data with wireless devices, I take a look on the DE1_i2sound project on DE1 cd, I saw that AUD_DACLRCK pin assigned to AUD_ADCDAT pin if I assign AUD_DACLRCK to input of my wireless tranciever and assign AUD_ADCDAT to my receiver will that work? or should I work on I2C controller? --- Quote End --- I dont know about DE1_i2sound on DE1 cd, but I think it is the same with one on DE2. In i2sound Demo, it doesnt matter what AUD_ADCDAT is assigned to, it just simply configures the WM8731 codec so that line input from mic is connected to speaker ( by pass or side tone mode - i dont remember :p ). It is not clear about your project, whether DE1 is source or sink. If you want DE1 could play sound from other devices via wireless, make sure that devices line-out is transmitted to AUD_ADCDAT. You also need information such as sampling frequency, bits per sample to generate correctly BCLK, AUD_DACLRCK ....etc.
