17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years agoHi friend, don't worry I've fixed the problem.
I run the program from the NIOS 2 IDE and works ! Thank you so much
