17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years ago --- Quote Start --- Hi Amigo, thank you for help me. Ive understand that example. Thank you. But now I've buy a SD_CARD that I've formated with FAT16 format and I've copied one song. But when I download the sof file to my board and I connected the speakers there's not sound played. How I can test the hardware ??? Maybe I'm forgot something?? It's very strange, could you help me please ?? Again thank you so much. --- Quote End --- SDCard to music demonstration using Nios II ( SOPC ). To make it work after downloading sof file, you need to use the program called altera_monitor_program to run NIOS II then music will come out :D. --- Quote Start --- it seems that the Line IN it's always connected with the LINE OUT?. --- Quote End --- yes, it is
