17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years agoOk, I think I should test the SD_CARD first and then the sound codec, otherwise I work very well with the I2Sound. Any recomendation on this topic ?
Also I've a small curiosity.. What's the difference if I run the demo from I2sound, because it seems that the Line IN it's always connected with the LINE OUT?.
