17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years ago --- Quote Start --- Yes, but you can't just divide a clock by 3 without violating duty cycle restrictions. You would need to use a PLL. When using a PLL, set the wanted frequency in the PLL MegaWizard. The MegaWizard will take care of selecting the best multiplication/division. --- Quote End --- thank you very much. I will use PLL as you suggest. >:D<
