17 years agoQuestion about sample rate of audio codec WM8731 on DE2
hi, everyone. I have read code from the DE2 I2Sound Demonstration and compared with WM7831 datasheet. Everything is quite clear, except the setting of sample rate. According to the datasheet, wh...
17 years ago --- Quote Start --- It's divided by 4, not by 2. The output clock changes state every second pulse of the input clock. So the full cycle is every four incoming clock pulses. Simulate it for better understanding. --- Quote End --- thank you, It is really divided by 4, I have misunderstood because of the name CLOCK_2. Therefore the MCLK is 12.5 Mhz ~ 12.288 Mhz. It is clear now. --- Quote Start --- Also, as you can see in the table, it doesn't have to be 12.288 MHz. It can also be 18.432 MHz. It depends on the BOSR bit. --- Quote End --- yes, in the demonstation, they set BOSR =0.
ROM= 16'h1000; //mclk so, for the sample rate of 44.1 khz, i need to divide 50 mhz by 3 ( 16.667 mhz ~ 16.9344 mhz ) and set bosr = 1 ? --- Quote Start --- Instead of using a divided clock, you can use a PLL to get a clock closer to the nominal value. --- Quote End --- Thank you for your suggestion.
