QuatusII-Prime Lite installation on University's PCs
- 6 years ago
There should not be a problem. As long as you have the correct Quartus installation files and the school PC able to support it, then you should be good to go.
It does not matter who download the Quartus, it does not make the Quartus any different with each other. What makes it different is its version and edition (lite/std/pro). Lite version does not required any license.
Please try to install it on 2-3 of your school PCs to check for any issue, and if you face any problem, please do not hesitates to contact us. It is difficult to further advise without knowing the actual problem.
Thank you for your answer.
However, the main purpose of my question is: To check if there is no problem even if I download the installation file (QuartusLiteSetup.exe) with the professor's id and install it all on the school PC .
It is difficult for students to sign up and download installation files because students taking classes each semester arechanged.
