9 years agoProgramming Fail De0 board
Could anyone provide me some insight into why this continues to happen? I setup a block diagram file with this logic: AB'CD'+A'BCD. I have four inputs mapped to the correct pins for the first ...
9 years ago --- Quote Start --- Ok, that should probably work. I assume when you launch the Quartus programmer that it can detect the USB-Blaster hardware? If so, then when you ask it to autodetect the devices, the correct one shows up (detected by scanning the JTAG ID)? Can you then do an erase / blank check on the device, and have it pass? --- Quote End --- It does detect USB Blaster hardware and it shows the JTAG ID. I installed Quartus on another PC. I made the exact same block diagram and had the same issue. BUT! I did get error codes when trying to program: 209014 CONF_DONE pin failed to go high in device 1 and 209012 Operation failed
