9 years agoProgramming Fail De0 board
Could anyone provide me some insight into why this continues to happen? I setup a block diagram file with this logic: AB'CD'+A'BCD. I have four inputs mapped to the correct pins for the first ...
9 years agoTry your board on another system that has Quartus tools installed and is know to be working in programming some other board(s).
Try another known-good Altera FPGA board on your Quartus install to see if you can get it to program. It may very well be you have either a bad FPGA board or a corrupted Quartus install. BTW you have never indicated which version of the Quartus tools you are trying to use, or what FPGA device/board you are using.
