9 years agoProgramming Fail De0 board
Could anyone provide me some insight into why this continues to happen? I setup a block diagram file with this logic: AB'CD'+A'BCD. I have four inputs mapped to the correct pins for the first ...
9 years ago --- Quote Start --- No I mean there should be messages about the failure to program when you click the Start button in the Programmer. They're usually red error messages if the Programmer was not able to complete the programming. --- Quote End --- I didn't see any error messages at all in the programmer. Just ran it again to double check. Is USB Blaster is the correct driver or should I use USB Blaster II?
