9 years agoProgramming Fail De0 board
Could anyone provide me some insight into why this continues to happen? I setup a block diagram file with this logic: AB'CD'+A'BCD. I have four inputs mapped to the correct pins for the first ...
9 years ago --- Quote Start --- Won't matter for this design, you can safely ignore the warning. It comes because you did not define any timing constraints on any of the I/Os, so Quartus is warning you of that. It will go ahead anyway and map the logic to the device, but it won't try very hard to improve the timing, since you provided no constraints. Most likely it is way faster than what you can do with your manual switches anyway. --- Quote End --- Thanks for the feedback. I still can't get a successful flash. The board does flash a light when it starts to program, then it immediately fails. I thought maybe it was the missing the constraints file for the board, but I added that and it didn't correct the problem. Any advice for getting the board to program?
