11 years agoproblems working through Using tse on DE2-115 boards from May 2015
Hi, The tutorial "Using Triple-Speed Ethernet on DE2-115 Boards seems not up to date although it says that it is for Quartus II 15.0 and is dated May2015: - Page 13, section 3.2 point 2&3 ...
11 years agoHi,
Just to close this, it was my mistake that I was looking in the IP Catalog of Qsys instead of Quartus II. And the document says: "Besides the subsystem built using Qsys, you need a Phase-Locked Loop (PLL) module to generate clocks with different frequencies to make the Triple-Speed Ethernet system work properly. The PLL will take a 50 MHz input clock, and output the desired clocks. To add the PLL block, perform the following:" Redirecting the reader (such as me :) ) back to Quartus would be useful in this document. Because both Qsys and Quartus have the IP Catalog window. I feel stupid.
