15 years ago
Problems installing Altera Monitor Program with NIOS II EDS 10.0
I have problems installing the Monitor Program with NiosII EDS 10. When running the installation file, it exits immediately saying it needs NiosII to install... Will this be fixed soon, or do I have to use an old version of NiosII EDS for now? I'm dissapointed that the new version only supports programming the Flash memory.. (or have I missed something? :-))
Thank you!
    no wonder i could not find the environment variable setting in quartus.
    thank you for your guide, finally i done my installation of altera monitor program.
    see the altera univesity program tutorial inctroduce the altera Monitor Program.
    Hello i would like to know if you have already solved the problem quoted here because i have got it too :
    --- Quote Start ---
    Now that I have these variables set:
    QUARTUS_ROOTDIR: c:\altera\10.0\quartus
    SOPC_KIT_NIOS2: C:\altera\10.0\nios2eds
    It complains that it needs a Quartus version 9.0 or later. The message is: Altera University Program Design suite requires (Version 4.2) Quartus II version 9.0 or later.
    I am using the installer: altera_upds_setup_vhdl
    --- Quote End ---
    I use Quartus 10.0 sp1 in C:\altera\10.0sp1\...
    Ok, i tried on another computer with the same design suite : 10.0sp1. I reinstalled quartusII web, niosII EDS, modelsim altera 6.5e. Then I updated the env variables. And i installed succesfully the university program.
    But back to my first computer (with 10.0sp1 too), it always complains with this message :
    If I don't want to reinstall the complete design suite. Maybe there is a hidden file or a stange environment variable stating the version of quartus currently installed in the computer.
    I am using vista and altera_upds_setup_verilog
    I have fully reinstall quartus modelsim nios2eds and university program UP and now it works...
