16 years agoProblems installing Altera Monitor Program with NIOS II EDS 10.0
Hello, I have problems installing the Monitor Program with NiosII EDS 10. When running the installation file, it exits immediately saying it needs NiosII to install... Will this be fixed soon, or ...
15 years agoIn windows 7, press win+pause to enter system information. Press Advanced system settings -> Environment variables and look for "SOPC_KIT_NIOS2" in the System variables list. If it doesnt exist, create it by hitting "new". If the path is not correct, edit it by pressing "edit" :)
I'm not sure, but I would guess you have to type "export SOPC_KIT_NIOS2="path/to/nioseds"" in system terminal if you're using Linux. wmlouds : it should point to where nios eds is installed Hope it helps :)
