16 years agoProblems installing Altera Monitor Program with NIOS II EDS 10.0
Hello, I have problems installing the Monitor Program with NiosII EDS 10. When running the installation file, it exits immediately saying it needs NiosII to install... Will this be fixed soon, or ...
15 years agoSorry to bring you back to this old quote, however I have tried adding the env. variable and get the same comment. What is supposed to be in the directory that is pointed to by the environment variable? (is it just where the monitor gets loaded or is it to have the nios files?) /thank you/ wayne
--- Quote Start --- OK. Someone figured out in the other thread. Just create an environment variable. I could not post link so I just quoted from the guy. It works! --- Quote End ---
