Problems in connecting to the DE10-Nano board using the Intel FPGA University Program
Hi JJian21,
Kindly check the USB-Blaster driver has been installed properly. Follow the steps in below links.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf
If the 'Host Connection' is blank, make sure the board is connected to the host by a USB cable and that it's power on. Then, press the refresh button and check. Follow the steps in below link - Page 10
ftp://ftp.altera.com/up/pub/Intel_Material/16.1/Tutorials/Intel_FPGA_Monitor_Program_ARM.pdf
Check the materials below for DE10-Nano board.
file:///C:/Users/cpalakrx/Downloads/DE10-Nano_User_manual_a_b%20(1).pdf
https://rocketboards.org/foswiki/Documentation/DE10NanoDevelopmentBoard
https://software.intel.com/en-us/iot/hardware/fpga/de10-nano
Hope it would be helpful for you.
Thank you.
Hi
I have problems in installing DE10 Nano driver. And Programmer of Quartus 2 can't find the De10 Nano connected.
So I found this topic. As you stated, I'm trying to install USB_Blaster 2 driver by using the link below (windows 10 installed):
I click on the apropriate link:
But the file comes as "firmware_2016-04-30---10-54-45.tar.gz" which is Linux compatible. And the links says "Windows* 7, Windows* XP, Red Hat Enterprise Linux 3, Red Hat Enterprise Linux 4" No windows 10.
There is something wrong with links, that i cant understand
