JJian21
8 years agoProblems in connecting to the DE10-Nano board using the Intel FPGA University Program
I can't connect to my board which is DE10-Nano while using the FPGA University Program. The version I downloaded is 16.1, and I found that the download link for version 17.0 is not correct. When I tr...
JJian21
8 years agoThank you Calvin!
My system is Windows 10, and I already install the driver by following the instruction in the board's SD card. Then I tested the "Play" function from the website also provided from the SD card. The LED light on the board could implement "Blinking" when I pressed the button from the website. Dose that mean the driver had already been installed successfully?
Do I need to install any other drivers?
