12 years agoProblem with Printf
I ve written a simple C-program running on Nios with output on JTAG-Uart Console. Why if the surce code is int m; m=9; printf("%d",m); everthing works perfectly while if the so...
12 years agoHi, telle us more information
for your 1st problem, What did you get ? "9" on nios2-terminal instead of 10 ? if so, clean and rebuild your nios project. Maybe the new soft was not correctly downloaded, did you get errors ? For your 2nd problem, When you chose Nios II/e (=economic version), do you regenerate the Qsys, recompile the design, redownload to FPGA, do you rebuild the BSP, do you recompile the soft ? regards
