13 years agoProblem with Pixel_Buffer_DMA and SDRAM
Hello guys. I have an Altera DE2-115 dev. board and I'm trying to use NIOS to display some images on a monitor, using the VGA connector on the board. I'm using quartus 11.1 and I'm following in...
13 years agoThat's fine, you can use all that memory for data processing as long as the on chip is used for reset and exception. If you ever find out why/how to do this with the sdram, let me know. I've seen tutorials on it but it flat out just doesn't work unless its the on chip.
