13 years agoProblem with Pixel_Buffer_DMA and SDRAM
Hello guys. I have an Altera DE2-115 dev. board and I'm trying to use NIOS to display some images on a monitor, using the VGA connector on the board. I'm using quartus 11.1 and I'm following in...
13 years agoHave you tried setting the reset/exception vector to on-chip memory? I had this issue also trying to implement a frame buffer for the project I'm working on now. (BTW if you get the back buffer to work using the pixel_buffer_dma driver please let me know, I've been having trouble with it). I found reading/writing for the SDRAM worked when I had on-chip memory for reset/exception but when I changed it to SDRAM, it no longer worked. Let me know if this helps.
