15 years agoProblem using TRDB-D5M Camera with SOPC Builder
I'm trying to use the TRDB-D5M camera connected to a DE2-115 with the UP video design examples. However I can't achieve what the example design file contained in following folder is supposed to do: ...
15 years agoSorry, it was my mistake. Audio and Video Configuration ip works fine,
the solution for DE0 was found =) I have attached my project. In this project i use 8-bit grayscale mode, 80x60 pixel buffer. I connect D5M module to GPIO_0 header. In the project folder a lot of unnecessary files, but the main thing here is the SOPC and the correct pinout (see bdf).
