alhussain779
3 years agoPower Monitor is not working on Stratix 10
I am trying to measure the power consumption of a design in my FPGA device using the Power Monitor utility that came with Board Test System. However, when I open it I get the following messa...
AqidAyman_Altera
3 years agoHi Alhussain,
Thank you for your verification on the status with the latest version of Quartus.
I really regret that the issue is still there.
One thing you can check is the default setup for the board. Have you check the JTAG switch in the board where the switch is to enable MAX V in the JTAG chain?
Aqid
alhussain779
3 years agoHi Aqid,
Yes, it's enabled.
I have also tried every possible JTAG switch configuration, no luck.
Alhussain
