alhussain779
3 years agoPower Monitor is not working on Stratix 10
I am trying to measure the power consumption of a design in my FPGA device using the Power Monitor utility that came with Board Test System. However, when I open it I get the following messa...
AqidAyman_Altera
3 years agoHello Alhussain,
Do you have any updates for this issue?
Aqid
alhussain779
3 years agoHi Aqid,
I would to thank you for your concern.
I just tried the latest version of Quartus which is 23.1.
I used firstly NIOS II command shell to test but it showed me the following message "jtagconfig: command not found"
So, I tried NIOS V command shell. jtagconfig command worked but still recognizing one device.
Do you have any other suggestions?
Alhussain
