alhussain779
3 years agoPower Monitor is not working on Stratix 10
I am trying to measure the power consumption of a design in my FPGA device using the Power Monitor utility that came with Board Test System. However, when I open it I get the following messa...
AqidAyman_Altera
3 years agoHi,
It seems system Max 10 is not detected in the JTAG chain causes the Power Monitor from the BTS can't be opened as there is mentioned in the message that you describe.
Also, from the log file, it also mentioned that the System Max 10 info array is not matched in the JTAG array.
Aqid
