Power Monitor is not working on Stratix 10
Thanks for your reply,
the MSEL settings I am using is the Avalon-ST (x8) Mode (110) as shown in the picture below:
I also tried all the other modes with no luck.
I checked the jtag chain with command jtagconfig --debug and I got the following output:
1) DE10-Pro [USB-1]
(JTAG Server Version 19.1.0 Build 240 03/26/2019 SJ Pro Edition)
C322D0DD 1SX280HH1(.|S3)/1SX280HH2/.. (IR=10)
Design hash 72AC4A992F0C88B023D5
+ Node 00486E00 Source/Probe #0
+ Node 00486E01 Source/Probe #1
+ Node 00486E02 Source/Probe #2
+ Node 00486E03 Source/Probe #3
+ Node 00486E04 Source/Probe #4
Captured DR after reset = (C322D0DD) [32]
Captured IR after reset = (001) [10]
Captured Bypass after reset = (0) [1]
Captured Bypass chain = (0) [1]
JTAG clock speed auto-adjustment is enabled. To disable, set JtagClockAutoAdjust parameter to 0
JTAG clock speed 24 MHz
Quartus Programmer shows only one device as shown in the following picture:
It seems like the MAX V CPLD is not in the JTAG path.
I have another board which is Arria 10 gx board and the power monitor works with it.
