alhussain779
3 years agoPower Monitor is not working on Stratix 10
I am trying to measure the power consumption of a design in my FPGA device using the Power Monitor utility that came with Board Test System. However, when I open it I get the following messa...
AqidAyman_Altera
3 years agoHello,
Thank you for reaching out to Intel FPGA Community.
It seems like a connectivity problem. This is my first guess.
Can you help to confirm if MSEL settings is correct and whether the devices involved and in the same JTAG path?
You can check using Intel Programmer also if the connection is detected or not.
If you have any other available board, can you confirm if there have the same issue?
