17 years agoPLL on DE2-70
Hello I was wondering if there were any good simple examples for using the PLLs on the DE2-70 written in Verilog. I was also wondering what the max clk rate is that can be generated from the PLL's us...
17 years agoI am a little confused. The mega function wizard asks for an input frequency for the PLL but I di not see it ask for an input pin or anything like that. I assume that I use a wire in the verilog to connect the input clk on the board to the pll then use the output of the PLL? Thanks fot the Help!
