Parallel Counter Block Diagram File Problem
I don't think it is a schematic problem since the simulation is fine.
Have you checked whether the design pass timing?
Try to debug design by using Signal Tap to check whether the waveform is correct.
- Bobd6 years ago
Hello:
Thanks for your reply. I had tried a timing simulation using the University Program VWF simulator and there didn't appear to be a problem. I believe that may use the simulator you mentioned as its tool as well, but perhaps not. Similar timing and functional simulations and compilations of other mod-number counters using the same feedback (MOD-12 using the 8 & 4 FF outputs, etc.) produced correct counts and it doesn't appear to be a debounce problem as the input used for the DE10-Lite is a 3.3V Schmitt Trigger type. I found when slightly re-routing the wiring to bring it more directly to the 2's count FF (see below) that the count seemed to be correct on the DE10-Lite board. After that, I could not duplicate the problem again with either schematic. I am wondering if somehow the programming file was corrupted during my earlier tests. In each case, I used the BDF as the top-level and compiled the project, and then used the programming file generated after compilation. Perhaps when saving the project (or if not saving in the interim), something changed? Still a bit of a mystery.
