10 years agoNot able to generate programming files for de1 soc board with cyclone5 fpga
Can someone pls explain how to generate .pof and .sof files for a de1soc board. it has cyclone 5 fpga. 5CSEMA5F31C6. I'm using a web edition.
10 years ago --- Quote Start --- Hi Akshatha31, Normally, assuming that you have a design ready to go within Quartus, you press "compile design" in the task window (open the task window with alt+6), and grab a coffee afterwards. Once compilation is done, you will have both *.pof and *.sof files in your project folder. You can upload the *.sof file to your de1 soc board using the button "program device". regards, Richard. --- Quote End --- Hi Richard, I did the normal compilation. But nothing is generated..! tried the convert programming files option too...But its asking for an initial sof file..Which isnt there....! Any other settings that I need to do?
