16 years agoNIOS II Interval Timer
Hi all, I have been struggling with NIOS II Interval Timer problem. I have done extensive search inside forum. I was able to find a few NIOS II Interval Timer posts + replies + working samples. ...
16 years agoSorry I don't have DE1 kit so I probably can't help you much. I assume it runs code from non-volatile memory? If so, are you sure the bootloader is properly set up to copy to RAM upon reset?
Peter
