16 years agoNIOS II Interval Timer
Hi all, I have been struggling with NIOS II Interval Timer problem. I have done extensive search inside forum. I was able to find a few NIOS II Interval Timer posts + replies + working samples. ...
16 years agoAre all your code sections in the same memory? Can you post your code section map? In the IDE, right-click on the BSP project, select Nios II > BSP Editor, and choose the Linker tab.
Also in the BSP Editor, there's a button to show the memory map of all devices. It might be helpful to others to post that. (Sorry I'm not using the IDE right now so I'm not sure exactly where that button is). Peter
