18 years agoNIOS II IDE: error msg 'The NIOS II ELF executable does not exist'
Hi!
Is there anyone who solved the following problem? when I run my project as NIOS II Instruction Set Simulator, the execution fails and appears the following ERROR MESSAGE: 'The NIOS II ELF executable does not exist. Please verify that the project built successfully' I thank you anyone who could give me an hint to solve this problem ;-) Best regards Paola4 Replies
The problem is solved!!!!
In the name of the folder of the project there was a SIMPLE space: this was the problem! Now it works! Bye PAola - Altera_Forum
I meet the same problem ...but I'm afraid I don't really understand you.The name of my project does not have the simple space,,,and the problem is still here...can you help me? Thank you very much.
it's a long time ago I did this project, but just to be sure, have you checked that in the overall path name of the project there are no spaces in? Hope this can help you, REgards Paola - Altera_Forum
--- Quote Start --- I meet the same problem ...but I'm afraid I don't really understand you.The name of my project does not have the simple space,,,and the problem is still here...can you help me? Thank you very much. --- Quote End --- hi i have got the same problem, do you know what do i do? thank you in advance,
