16 years agoNios 10 message error
Hi When I try to run my project as Hardware in a DE2 board, I get the following message: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not respo...
16 years agoThere can be several causes:[list][*]bad clock input, or no clock at all[*]bad polarity on the reset signal, that keeps the CPU stuck in the reset state[*]design not meeting timing requirements[*]no license for the CPU, and the Opencore evaluation window has been closed (if you don't have the license, don't click on the 'Cancel' button).[/list]
