17 years agoNetwork Supervision
Hi all, I'm just starting 'my adventure' with Altera DE2 and I've been given a project that requires reading data from board's registers and passing it to a program on a computer via the Ethernet ...
17 years agoIn fact, just a small correction... wherever I put TXT[some payload byte] = *switch_pio in the loop (even after a few packets being sent), the configuration of switches will be read only once and after that every next call to the switches will keep the same value. It's as if reading the switches causes them to freeze.
I hope, if there is another version, it'll help. I look forward to hearing from you. cheers, Adam
