17 years agomy SDRAM takes 14 clock cycles to read data !
i'm using the sdram on the altera de2 board i've connected a master component to the avalon-MM, that's supposed to perform reads from a slave (sdram controller) connected as well to the avalon bus...
17 years agothanks for your replies ... after reading the sdram datasheet it seems that it's normal due to so many latency parameters, so it' about 5 clock cyles to read 16 bits and then so as to read 32 bits we will need to a double time : 10 clock cycles, the avalon bus should perform 2 successive reads making the full read operation more late ...
